hi
I'am Astrit
I'am inginiers and I'am new in bently inroads
I ned help
How too create a projeste.
How too start the work the perst step because as I tell I'am new and I dont now
Thenks
Astriti
  • please
    I neead your help.
    I dont know how tu create surface how tu inport the point and dhe brekline
    I have dhe DTM in DWG or DGN format and I neead tu inport in Inroads too create surface.
    please help me
  • Hi Astrit,
    First question would be which version of InRoads are you running. This is shown in Help->About Bentley InRoads.
     To first create a surface you need to go to File->New and click on the Surface tab. You can type in a name for the surface and a description and create a surface that way. From there you can use the File->Import->Surface or Surface Advance tools to bring in features. Surface advance allows you to import surfaces in a Batch run. This is useful but takes a bit of setting up.
    You should also go to File->Tools->Named Symbology Manager and File->Tools->Style Manager and create the styles you want your features to look like.
    If you have XM edition (V08.09.##.##) they have video tutorials showing you how to run the File->Import->Surface Advanced tool. If not Bentley also run training courses which can be found here  http://www.bentley.com/en-US/Training/Products/default.htm
    HTH
    Mick
  • You can also get PDF's and example data sets from Bentley's web site. These tutorials have a "Getting Started with ..." section and introduce you to the products in a gradual way.
    http://communities.bentley.com/Wiki/view.aspx/InRoads_Product_Tutorials
    These are for XM (8.9) but  also can apply to V8i. There are aslo locations where the 8.5 versions are stored.
    Charles (Chuck) Rheault
    CADD Manager
    • MicroStation user since IGDS, InRoads user since TDP.
    • AutoCAD, Land Desktop and Civil 3D, off and on since 1996
Reply
    CADD Manager
