I have a student using a 64-bit win7 version of inroads V8i Select Series at his home and coming in to our lab (32-bit winXP with V8i) his dtm files are not recognized.
The default save format for V8i Select series is an 8.11.7- is there a way to change this default save version and can V8i select series work with legacy dtm files?
Denis,
Just curious, is there new data now stored in the alg and dtm that warranted the new file versions, or is it just a different file structure? When you save it down, does it delete any data, or does it simply make it so the previous versions ignore it? Thanks.
Chris
Hi Chris,
Yes there is new data stored, so you will lose information if you save it down. (Overlay Component properties in the dtm, and something I can't recall in the alg)
Denis
