DTM load default settings
I read on an earlier thread that you can use the variable GPK_LEVEL_SET_BYLEVELS = 1 to set all symbology to be level.  I have not had any success with this variable.  I'm using 08.11.07.229.  I have checked both the pattern lines dialog box and the DTM load dialog box and the symbology is still set to specific values.  Is there a way to have DTM tools by default load a standard .lpf file?
  • Rick,
    Let me explain what this variable does. If you open a dialog like Draw Patterns, it has a "symbology" dialog that can be opened to allow the user to set the symbology of their pattern lines. When you open it, it will be set to a certain level, color, style and weight - whatever the defaults are. Without the variable being set, you would have to select your level, then MANUALLY set Color =  ByLevel, Weight = ByLevel and Style = ByLevel. With this variable set, when you select a level the Color, Weight and Style will AUTOMATICALLY set themselves to ByLevel. But note that you have to select a level.
    You should be able to use the following variable to have the DTM tools load a standard .lpf file.
    GPK_DTM_LOADDEF
    Derricke
    This is a test
Reply
  • Rick,
    GPK_DTM_LOADDEF
    Derricke
    This is a test
