Copy Parallel Error-Site Modeler
I encountered the following error while doing the copy parallel to generate the inside edge of roundabout.
Microstation V8i Selectseries1 - 08.11.07.180
Geopak V8i Selectseries1 - 08.11.07.227
  • Use Microstation to Copy the element parallel the use the new edit element dialog and slope offset command...
    I have seen this message before with complex elements, I believe it is due to the resulting slopes crossing on the created parallel element.
    Mike Barkasi
    Bentley Civil Professional Services
    Michael Barkasi
    Application Engineer
    Reality Modeling
  • All,
    Attach the required data set.
    Cheers,
    Junz
    Copy Parallel.rar
  • Hi,
    I didnt see anything to indicate which element was the one that could not be copied... so I just started looking at the project in general.
    There was 3 elements in the Roadway Object.
    The outer edge of the roundabout (which is an alignment) and then 2 arc elements inside the outer edge that may have been for a lane??
    Anyway, those elements looked a little odd. Element information on one of those elements returned an odd result. And the Model didint appear to be merging as expected... so it seemed like something was a little off.
    So I deleted both of those elements.
    I then used the copy parallel on the outer circle at a 2% slope ... and the result looks good.
    Without knowing exactly what you were trying to do - I had to "guess"...
    I've attached the dataset - this seems to be OK now and ready to move forward.
    HTHs
    Temp.zip
  • Hi,
    I didnt see your "workflow" post before responding to your post that included the data... so these are a little out of order.
    You workflow seems sound.
    I'd suggest leaving a small gap in the outer circle... our co-ordinate geometry engine doesn't like a chain that is a 360 degree arc. Just leave a little gap in that circle - probably adjacent to the centerline of an incoming roadway would work well.
    Try this, it may clear up some of the problems you are having.
    Michael
Reply
  • Hi,
    Michael
