Please help.
I've 2D spot heights with text and I'm trying to convert these to 3D to create a DAT file, however after searching this forum I can only find solutions regarding to InRoads which doesn't seem to work in Powercivil. Some guidance if I can in Powercivil and how I can do this will be greatly apprecaited.
Thank you
Neil Wilson (aka Neilw)
Power Civil v8i 08.11.07.245
AutoCAD Civil 3D 2018
Neil provided one option.
The other option is DTM>Extract graphics.
Populate the dialog as shown below. I have the "level" field empty at present. Enable as many symbology filter options as required to isolate the text you are interested in. Then click the "match" button and select the piece of text to automatically populate the filter fields.
The "content" option at the bottom of the dialog tells the tool to "read" the text value as the elevation. The XY location will be the text justification point.
That should create the DAT file you are looking for.
HTHs.
Thank you both, that has helped loads and saved laods of time.
Cheers
Williera
