MX Error/Warnings
Hi all...
Can any body plesae let me know how to fix the error no E0385 and E0350
i.e. Start/end point on reference string outside range of last 804 option
Scale not set by as 803 option
With and Without using the line mode option
 Thanks......
Bibhu
  • Bibhu,
    E0350: You are (probably) trying to over draw a model on an empty display. Ensure that you use an 800 / 803 option and not an 801.
    E0385: These errors are possibly related to each other. There are a number of reasons why they could occur: are you trying to design or plot on a cross- or long-section drawing? Try Display > Erase Display... and running the file again. Sometimes an error in the input file (either a user-error or program-error) can reset the display. Run the file again on a fresh MX session in a new DPW and see if you still get the problem. If you do then you should post the file for us to check...
    S
  • Thanks Scott for your reply...I will try your information. Could you plese let me know how this problem can be resolved if I am not using an input file. or could you please send me an input file to resolve this issue.
