I´m using IR version 08.11.07.229 and MS version 08.11.07.171. I can´t start IR directly from the desktop, the following message shows after MS starts: "OS could not load C:\PROGRAM FILES\BENTLEY\INROADS GROUP V8.11\BIN\CivUstAT.dll, error 126.
MDL loader: Unable to load library <DLL or MDL shared library> CivUstAT."
However when I already have opened MS and choose Utilities->MDL application-> browse-> C:\PROGRAM FILES\BENTLEY\INROADS GROUP V8.11\BIN\CivUstAT.m IR starts normal.
Have I installed IR or MS wrong in some way? I havn´t changed anything from the "normal settings" in the installation.
InRoads must be started from the Start menu at least once after installation before the desktop shortcut will work.
HTH, Ron
I removed and installed both MS and IR.
I get the same problem when I open it from the start menu (the same text window pops up). And it still works fine when I open it from Utilities=> MDL application.
Please help...
Karl,
I have similar case as your. Just not the same vision as your. I can run normally in MS SS2 with IR SS1; but don't know why it hanged when running MS SS2 with IR SS2 and error 126 is showing. Could your please to tell me how to fix it?
Leo
Leo,
Are you attempting to launch InRoads from within the MS session?
Michael,
I have used any methods to launch InRoads, e.g from the strat buttom program group; lunching from desktop icon; dubble tick the InRoads.exe; calling from V8i application pull down menu and running at MDL. All the results are hanged or error 126.
One thing I can understand is it ran normally at the first time (just installed), but the error occured next time till to now.
Leo.
Are you using the project defaults dialog box to set an XIN file to load? Years ago I found that if I tried to load a bad INI file via project defaults it would lock up. I have not had issues like this in some time, but its worth a look.
Fixed it now. It was coursed by my windows user right of profile, created an other new user profile, then everything alright now. Anyway, thank you everybody.
