No Cross Section Cell to process
When trying to cut cross sections in GEOPAK, I get the following message:
"There are no Cross Section Cell to process with regards to current settings."
There are cross sections cells that get generated and I can put those into a cross section file, however, the existing ground surface is not generated.  Is have checked the .tin file and all seems to be correct with that.  How do I generate the existing ground surface on the cross sections cells that get generated?
 MS Version 08.05.02.55
GEOPAK 08.08.02.81
TIA
  • Hi David,
    did you use the Draw XS tool to draw the existing surface XSs?
    This tool expects a Hz alignment and a TIN file.
    It then draws the XS cell and the existing surface (from the TIN) into each cell.
    You say that "There are cross sections cells that get generated and I can put those into a cross section file, however, the existing ground surface is not generated.". How did these XS cells get generated in the first place??
  • I am using the Draw Cross Sections from Surfaces option.
    I do specify a horizontal alignment and a .tin file.
    I have a pattern shapes file with line work in that file at the stations where I want cross sections cut.  Using the Draw Cross Sections from Surfaces option, I specify the pattern shapes file to look into and also specify the level of the linework that  Ihave pattern lines drawn on where I want the cross sections to be cut.  When I select 'draw', the cross sections are processed and the XS cells are placed (ie: cut at the correct stations) but the existing ground surface is not generated and put onto the XS cell.  I get the error message that I indicated in my first post.
     I guess I don't know how the XS cells got generated in the fist place, all I know is that they do get generated but without the existing ground surface.
  • David,
    please send me your Plan DGN, your Pattern Line DGN , your GPK file and your TIN please.
    Place them in a ZIP file and send to:
    michael.gilham@bentley.com.
    I'll take a look at your data.
  • We resolved this problem.
    The folder path contained characters that GEOPAK 2004 didnt like. We removed the offending characters and the tool works as expected.
  • Hello Mr. Gilham,
    My name is Kevin. I am working out of Power GEOPAK V8  and designing a road design for a subdivision plat using the Road Manager. Previously I did not have an issue creating cross-sections for the road but recently I have been getting the same error message  "There are no Cross Section Cell to process with regards to current settings." I wanted to know if you could assist me with this matter at you earliest convenience.
    GEOPAK 08.08.02.81
