Dear friends, please help me. I have got one problem in mXROAD XM with vertical profile.
After i finish with my horizontal alignment, i can start my vertical profile from quick alignment and it works ok. but after i correct my horizontal alignment iam not able to go into vertical profile again. It has happened to me many times. The only way is to start a fresh design again leading me to wastage of time.
Can any one tell me why is this happening and how to correct it.
Thank you all
This process should be ok. Is there an error message displayed when it won't go into vertical ?
Ian
Dear Ian Thanks you so much. In quick profile i have to enter my string name eg MC00 and surface model eg Triangle.TXT. Usually when i enter these two parameter, MX should take me to vertical profile alignment design. but it is not taking me inside and it is asking me to enter it again and agian and do not take me inside. no other error messages are displayed..
thanks
tougay
Hi
Thank you so much. I will try that out and report back to you. By the way how can i increase or decrease cross section interval. is it in the style set editor? I could not find it.
Hallo,
It depends on what you are thinking about: the interval of cross sections or the interval of cross sections working drawings.
First case:Whan you are creating cross section you should place "X" by "Limit or Add Section Locations" in "Reference Details" panel. In last window you define a location of Cross Sections (interval, special chainages etc.).
Second case:Whan you are creating working drawings of cross section you just select the interval of section.
My advise is to create a cross section in every point of reference string and limit them when create working drawings.
Best Regards,Aleksander Zamorski
There is a third case in the final drawings sheeting options, basically after cutting all the sectionsat every reference point you simply define a list of sections to be used for sheeting purposes. This list is saved and can be reused / modified.
Hi to all
Thank you so much. yes i got it. it works. Thanks again.
Dear Ian
I have data in DWG format. How can i convert it to excel format? I need to convert some features to points in excel sheet before i turn all of them to DXF data to be process with MX.
