Vertical profile
Dear friends, please help me. I have got one problem in mXROAD XM with vertical profile.
After i finish with my horizontal alignment, i can start my vertical profile from quick alignment and it works ok. but after i correct my horizontal alignment iam not able to go into vertical profile again. It has happened to me many times. The only way is to start a fresh design again leading me to wastage of time.
Can any one tell me why is this happening and how to correct it.
Thank you all
  • Hi tougay,
    Try to go to Element Method and delete GDS model. Than go one more time and should be ok.
    Remenber to create an M-string of horizontal alignment before deleting GDS. Finally:
    1. Create an horizontal alignment and craete M-string (and leave alignment design),
    2. Go to alignment design via Element method and select Your model (i.e. DESIGN),
    3. Place "X" in "Delete GDS?" box, select "DESIGN   GDS (GDS)" and click "Delete GDS?" button,
    4. Select Your model (i.e. DESIGN) and go to "Horizontal Design >",
    5. Place "X" in "Retrive Alignment" box and select on screen Your M-string of alignment,
    6. Select "Next >", than a green "V" sign (if You don't want to amend a horizontal alignment),
    7. Go to "Vertical Design >" and design :)
    Best Regards,
    Aleksander Zamorski
  • Hi
    Thank you so much. I will try that out and report back to you. By the way how can i increase or decrease cross section interval. is it in the style set editor? I could not find it.
    thanks
    tougay
  • Hallo,
    It depends on what you are thinking about: the interval of cross sections or the interval of cross sections working drawings.
    First case:
    Whan you are creating cross section you should place "X" by "Limit or Add Section Locations" in "Reference Details" panel. In last window you define a location of Cross Sections (interval, special chainages etc.).
    Second case:
    Whan you are creating working drawings of cross section you just select the interval of section.
    My advise is to create a cross section in every point of reference string and limit them when create working drawings.
    Best Regards,
    Aleksander Zamorski
  • There is a third case in the final drawings sheeting options, basically after cutting all the sectionsat every reference point you simply define a list of sections to be used for sheeting purposes. This list is saved and can be reused / modified.
    Ian
  • Hi to all
    Thank you so much. yes i got it. it works. Thanks again.
    tougay
