IR SS1 (246)
for about a week i get this message each time i save corridor and tmls (i didnt have this problem on the same project before but i did mess a bit with variable manager). i created both tml, corridors stles from skratch. i got metric option selected in project defaults, i tried to save tml/ird with options convert imperial to metric. still nothing. why i get this message? how to set it back to metric?
hi,
your XIN is set right (Project Options). Please check units in your ITL (see attached screen).
Piotr
still everything set to metric. imo this is some kind of IR glitch. i didnt have this before tho. (like 3 weeks ago with the same version)
Please check you IRD file. There is unit definition as well.
You can send me your XIN ITL and IRD file and I will test them on my PC.
I have managed with this problem in that way(do copy of Your ITL before):
step 1: Save as.. --> Options --> Convert Metric to Imperial and save Your ITL with this option
step 2: Save as.. --> Options --> Convert Imperial to Metric and save Your ITL with this option
For next savings set no convert.
after these operations problem disappeared.
Kind regards, Kzzysztof
yes but converting messes up units (lenghts of verticals, horizontals). and every time creating new roadway, templates you never know if you get the same error msg again.
