Mainline = Blue Stationing
Crossover = Red Stationing
Is this what a properly clipped vertical gore is supposed to look like? It seems to me the Crossover should be clipped to the mainline. The crossover is a complex template that includes base and subbase material. 16 - foot wide with a 2 - foot shoe.
What is the application?
This is InRoads XM, trying to use the vertical gore tool.
Sorry, don't know IR :(
thanks anyway.
Using the vertical gore tool does not automatically clip the corridor. It is simply a tool used to help you create the vertical profile for a ramp. You need to add Target aliasing to accomplish that.
HTH,
Denis
