Modeling Existing Utilities in InRoads XM
Thanks in advance for any help or advice.
I am looking to model a set of existing utilities inside of Inroads XM, using the drainage utility command.
The Utility that I have currently modeled, as a trial run to figure out the best work flow, represents an existing
rectangular drainage culvert.  The culvert was created successfully in the utilities tab and shows when viewing
drainage as solids.  My issue now is I want to see the existing Utility show up in my Profile when i cut it along
my horizontal alignment.  to this point i cant seem to get the crossing of this utility to show.  Therefore my
question is....
How do you get Utilities to show as crossings when creating Profiles or Sections?
Does this information have to be brought into the DTM as a Feature for it to show?
Enough for now...
Thanks again for your insight and direction
Best Wishes,
Kevin.
  • The display is based on the Style you used for the utility.  The Style would need to have the Surface Feature Cross Section Display and Profile Display Crossing Points toggled on.  The style has to be asociated with a Name Symbology that has a line display set for cross section and/or profile also (that is what would be used to display the shape).
    This is a test
  • Hey Art,
    Thanks for your response....
    It looks as thought my settings are correctly set in my Style Manager as well as the associated
    symbology.
    I am assuming by your reply, that i would not than, have to include the culvert information in the DTM as a feature,
    to get this information to show up.
    My question than would be.  This information is represented as a utility in the
    drainage database, how than does my profile know to include it in the profile i am generating.  I do not see a
    switch to select to include... it seams their would be a utilities box on the Network Tab of structures to view.
    Thanks again,
    Kevin.
  • You will need to toggle on Include Drainage Structures.
    I would do it as an Update Profile or Cross Sections instade of directly from the Crate Profile or Create Cross Sectin command so I could be "picky" at what is being displayed out of the Drainage Database.
    This is a test
  • Just adding my $0.02.
    I have used both DTM Features and Drainage Utilities and both can work. Each has its advantages and disadvantages too.
    Charles (Chuck) Rheault
    CADD Manager
    • MicroStation user since IGDS, InRoads user since TDP.
    • AutoCAD, Land Desktop and Civil 3D, off and on since 1996
  • Where do you toggle on include drainage structures?
    On the Create Profile dialog under the Include tab lists:
    Crossing Features
    Projected Features,
    Display Planimetrics
    Show Data Outside Elevation
    Display Manholes as Cones
    No Drainage Structures.  Is this were you are referring?
    Also, on the Update Profile Dialog, it doesnt list anything for Drainage Either....just:
    Surface
    Offsets
    Crossing Features
    Projected Features.
    When i look at the crossing features, i see some random points but that is it...
    I assume thats only because thats all that is in my DTM...
    Kevin
Reply
    Crossing Features
    Projected Features,
    Surface
    Offsets
    Crossing Features
    Projected Features.
    Kevin
