Have one feature code that is not being recognized.
It does not visualize and when looking at the points with that code in the survey editor the Geometry column is blank, i.e. no P for Point.
The feature code is: 10 and there are other codes such as 1011, 1047 etc.
In the smd it is set to a point, not linear, with the standard cross symbol and font. The level is on to display the point symbol and labels.
Geopak PowerCivil 245 and the previous 22?
Befuddled.....
not sure I understand the situation.
You have imported Survey data. Correct?
One of the field codes used in that Survey data is "10" and the points with that code do not display - correct? Do you have an SMD item for the code "10"?
Lets start there... I'll respond further once this info is clarified.
Yes, there is an SMD feature code "10" defined. The points are ascii xyz coordinates imported into the database.
Please post the data.
DGN
GPK
SMD
ASCII data.
Put data into a ZIP file and attach to this thread and I'll take a look.
Attached....
This may be the problem.
The SMD feature code "10" has been set as a type "cell" - but no cell is assigned.
Reset that feature code to symbol and try again.
