Have one feature code that is not being recognized.
It does not visualize and when looking at the points with that code in the survey editor the Geometry column is blank, i.e. no P for Point.
The feature code is: 10 and there are other codes such as 1011, 1047 etc.
In the smd it is set to a point, not linear, with the standard cross symbol and font. The level is on to display the point symbol and labels.
Geopak PowerCivil 245 and the previous 22?
Befuddled.....
Thanks for the quick response!!
Had already tried that and just tried it again, when changed to symbol the "Point Feature" turns on with a default of "A". Cannot seem to turn this off. On other feature codes can use the "Point Locater" symbol cross without the point feature turning on even though cell is on, not symbol. Under culvert in the smd look at 1104, for example. This works as expected with the cell on but not defined.
I reset that option from Cell to Symbol.
I did not set a symbol - I basically wanted it to draw the + only.
I then visualized that data.
All the "10" coded points (ground shots) now have a + symbol and the Pt#, Elevation & Dexcription are written to each point (see attached image).
Can you try it without enabling the symbol and see if you get bthe same results as I do.
This will give us a baseline to work from.
Have tried that and could not get the default "A" to not visualize.
Unchecked the "Point Feature" box in upper right corner and .........
they display as expected.
Thanks for your help!!!
thats the upper left of the smd manager!
I've contacted the Support group.
Someone from Support will contact you and assist in resolving the problem.
HTHs
