InRoads SS1 Running in MS SS2 - Display Features in Cross Section
Ok,  I updated MicroStation SS1 to SS2 and running InRoads SS1.  When I try to update my cross sections with displaying crossing surface features (as a cell), the features appear at the incorrect scale.  It appears that the cells are not being scaled to the desired scale factor.  Has anyone else run into this situation.
Thanks in advance,
Chuck
  • Chuck,
    I cannot reproduce this issue. Which scale factor are you using?
    File > Project options > Factors > Cell Scale.
    When I display a crossing feature as a cell, it appears to be obeying the factor defined in the named symbology as well as the global scale factor as described above. If i use a scale factor of 2 in the named symbology and then a factor of 5 in the cell scale symbology, the plotted scale has a factor of 10= 2*5.
    Are you not experiencing this?
    Thomas
    This is a test
Reply
  • Chuck,
    Thomas
    This is a test
