GEOPAK Drainage drgmsg.txt file
Can anyone explain why items from other Networks are listed when Designing or Analysing a Network within Drainage?
On a related note, are there any plans to enhance this error reporting system to help pinpoint issues?
Aaron
  • Aaron;
    Drainage It is designed that way; during a Design and/or Analyze, all the components in the GDF go through a "verification" process and are reported in the resulting drain message txt file.  There is no way to separate them out or to pinpoint components that are not specifically named during the reporting process.
    However, you can easily write spreadsheet formulas and/or macros to analyze the resulting csv file from the Report Builder and locate these components by name or exact location in the file, such as I have done and uploaded free copies to my website.
    You can find these free spreadsheets with instructions on usage here:
    www.dtm-solutions.com/.../downloads.php
    You can write similar spreadsheet formulas to remove non-active network components from the drain message txt file or I can do this for you.
    Hope this helps,
    dan@dtm-solutions.com
