Corridor Modeler DDB ....
I was wondering where I can define which DDB to use with Corridor Modeler?
Mine is set to default and I cannot change the directory (grayed out) I can only import.
Is this variable defined somewhere else in GeoPak?
  • You can use the following variable to define your own DDB.
    GPK_ACBOOK_DDBFILE_STYLES =
    If you want to go a step further, you can also import the DDB and create the XIN, then point to the XIN with the following variable:
    GPK_ACBOOK_XINFILE_STYLES =
    Note that all the CM variables should be documented in the Help.
    Derricke
    This is a test
  • Just a 2nd note ... once you set the DDB variable, your old DDB will continue to show up unless you remove the RSC files OR use the FORCE variable.
    Derricke
    This is a test
  • The path I have shows the correct path, but the DDB file line is still grayed out and not the correct file.
    Thank,
    Dan
  • i don't think you can use a wildcard.
    For more information about the Road and Site design tools, visit the Road and Site design WIKI at: http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
