Inroads XM & MicroStation V8i (SS1 or SS2)
Can Inroads XM be run on newer versions of MicroStation?
If not, what migration paths are required for Inroads XM to Inroads V8i. What's involved?
  • InRoads V8i (SELECTseries 1) Can be run on MicroStation V8i (SELECTseries 1 or 2). I do not recommend trying to run InRoads XM on any MicroStation version other than XM or 2004 edition. I would go ahead and upgrade.
    Install the new products on the machine to their respective locations. They will co-exist with XM products on the machine since they are in separate folders from the XM products.
    As far as migration, you should not have many issues. A few preferences will have to be revisited because of the upgrade. Data files for InRoads will automatically upgrade. Be sure to do a Save As > Options if you want to save the  InRoads data back to XM format. As far as MicroStation forward migration, you may need to post on the forum or search the ask Inga forum.
    HTH
    Thomas
    This is a test
