Where are GEOPAK SS2's .rsc files stored by default on a Windows 7 64-bit installation? In the past I used a batch file to delete all .rsc files in GEOPAK's bin directory if necessary. Where should I point this batch file to now?
Josh Mauritz
MS v08.11.07.443GPK v08.11.07.427Windows 7 64-bit
It will be different on every computer based on your user name and version of MicroStation. On mine it is
C:\Users\Derricke.Gray\AppData\Local\Bentley\MicroStation\8.11\7wluuhxFFX1cmFA2Mrvnsw\GEOPAK
Note: You can re-direct the RSC files using the GPK_RSCDIR configuration variable.
Derricke
Here is the code out of a VB 6 form we created to delete both the rsc files and the upf. We use the new variable that Derricke references so it doesn't matter if you know where the resource files are as long as MicroStation knows.
VERSION 5.00Begin VB.Form UserFormDeleteRSC Caption = "Delete RSC and UPF Files" ClientHeight = 1515 ClientLeft = 60 ClientTop = 450 ClientWidth = 3780 LinkTopic = "Form1" ScaleHeight = 1515 ScaleWidth = 3780 StartUpPosition = 3 'Windows Default Begin VB.CheckBox CheckV8i Caption = "Delete MicroStation V8i RSC Files" Height = 255 Left = 360 TabIndex = 3 Top = 120 Width = 3255 End Begin VB.CheckBox CheckBoxUPF Caption = "Delete MicroStation V8i UPF" Height = 255 Left = 360 TabIndex = 2 Top = 360 Width = 2895 End Begin VB.CommandButton Command1 Caption = "OK" Height = 375 Index = 1 Left = 1920 TabIndex = 1 Top = 720 Width = 1215 End Begin VB.CommandButton CommandButton2 Caption = "Exit" Height = 375 Index = 0 Left = 480 TabIndex = 0 Top = 720 Width = 1215 EndEndAttribute VB_Name = "UserFormDeleteRSC"Attribute VB_GlobalNameSpace = FalseAttribute VB_Creatable = FalseAttribute VB_PredeclaredId = TrueAttribute VB_Exposed = FalseDim counter As IntegerDim DirectoryCounter As Integer
Private Sub Command1_Click(Index As Integer)
DirectoryCounter = 0counter = 0If UserFormDeleteRSC.CheckBoxUPF.Value = False And UserFormDeleteRSC.CheckV8i.Value = 0 Then MsgBox "Please check what you would like to delete on the dialog" Exit SubEnd IfDim TheFileName As StringDim TheFullName As StringIf UserFormDeleteRSC.CheckV8i.Value = 1 Then CheckPathV8i = MicroStationDGN.ActiveWorkspace.ConfigurationVariableValue("GPK_RSCDIR") '"C:\BentleyV8i\GEOPAK\V8.11\bin\" CheckPath64_12_09 = "C:\BentleyXM\Geopak\V8.9\bin\" CheckPath64 = "C:\Program Files (x86)\BentleyXM\Geopak\V8.9\bin\" CheckPath = "C:\Program Files\BentleyXM\Geopak\V8.9\bin\" TheAvailablePath = Dir(CheckPath, vbDirectory) TheAvailablePath2 = Dir(CheckPath64, vbDirectory) TheAvailablePath3 = Dir(CheckPath64_12_09, vbDirectory) TheAvailablePath4 = Dir(CheckPathV8i, vbDirectory) If TheAvailablePath4 = "." Then 'CheckPath64 for newer machines December of 2009 mypath = CheckPathV8i ElseIf TheAvailablePath = "." Then 'CheckPath mypath = CheckPath ElseIf TheAvailablePath2 = "." Then 'CheckPath64 mypath = CheckPath64 ElseIf TheAvailablePath3 = "." Then 'CheckPath64 for newer machines December of 2009 mypath = CheckPath64_12_09 End IfDim MicroStationVersionPath As StringMicroStationVersionPath = mypath Myname = Dir(mypath, vbDirectory) ' Retrieve the first entry. Do While Myname <> "" ' Start the loop. If Right(Myname, 3) = "." Or Right(Myname, 3) = ".." Then GoTo Skip ElseIf Right(Myname, 3) = "rsc" Then Kill mypath & Myname counter = counter + 1 End If On Error Resume NextSkip: Myname = Dir Loop'*************** Go through WOrking Directory ****************** mypath = ActiveDesignFile.Path & "\" ' Set the path. Myname = Dir(mypath, vbDirectory) ' Retrieve the first entry. Do While Myname <> "" ' Start the loop. If Right(Myname, 3) = "." Or Right(Myname, 3) = ".." Then GoTo Skip1 ElseIf Right(Myname, 3) = "rsc" Then Kill mypath & Myname DirectoryCounter = DirectoryCounter + 1 End If On Error Resume NextSkip1: Myname = Dir Loop MsgBox CStr(counter) & " RSC Files Deleted off " & MicroStationVersionPath & " " & CStr(DirectoryCounter) & " RSC Files deleted from working directoy"End IfIf UserFormDeleteRSC.CheckBoxUPF.Value = 1 ThenOn Error Resume Next MsgBox "UPF File has been deleted. MicroStation will now shut down." MicroStationDGN.Quit DoEvents V8iUPFFile = "C:\Docume~1\" & UserName & "\" & UserName & "V8i.upf" TheUPFFile = "C:\Docume~1\" & UserName & "\" & UserName & "XM.upf" TheDirFile = "C:\Docume~1\" & UserName & "\" & UserName & ".dir" Kill TheUPFFile Kill TheDirFile Kill V8iUPFFileEnd IfEndEnd Sub
Private Sub CommandButton2_Click(Index As Integer) EndEnd Sub
Private Sub Form_Initialize()Dim CompName As StringCompName = "." Set objWMI = GetObject("winmgmts:" & "{impersonationLevel=impersonate}!\\" & CompName & "\root\cimv2")
Set proc = objWMI.ExecQuery("Select * from Win32_Process Where Name = 'ustation.exe'") If proc.Count > 1 Then 'MsgBox "There are more than one instance of MicroStation Running!!!" ElseIf proc.Count = 1 Then 'MsgBox "There is only one instance of MicroStation running." Else MsgBox "MicroStation must be running in order to set Variable paths for this program to know where to find RSC and UPF Files. Please start MicroStation and run this program agian." End End If
End Sub
Josh,
Is there any chance you'd post the code for that batch file?
Aaron
The code we use is simply:
@echo off
title Delete GEOPAK rsc files
color 1E
del C:\Users\Josh.MFLD.009\V8iSS\GEOPAK\*.rsc
pause
exit
It is just saved as a .bat file that can be run from the Windows Start menu. We use a modified MSLOCAL.CFG file (pointed to by a custom shortcut) that sets _USTN_HOMEROOT = $(USERPROFILE)/V8iSS/. I assume this is how GEOPAK knows to store its rsc files under this directory.
HTH,
Josh
Please refer to the following article for Deleting GEOPAK Resource files.
communities.bentley.com/.../15923.geopak-resource-files-how-to-remove-them-and-why.aspx
