Need help working from home with your Bentley software? We're here to help - click here
Roadway Designer Key Stations and Template Drop interval
Is there a way to have the Key Stations not interfere with the template drop intervals? For example, if I drop a template at station 100+00 at a 50ft interval, I want sections cut at:
100+00
100+50
101+00
101+50
If I put a key station at 100+62.00, then the interval stations adjust to:
100+00
100+50
100+62
101+12
101+62
etc.
Is there a way the original interval stays the same, with the inserted key station? So:
100+00
100+50
100+62
101+00
101+50
As it is currently, this causes a problem when actual cross sections are cut for Geopak users as our pattern lines are set up at the "normal" 50' interval causing interpolation sections, inaccurate for earthworks. (Note: This is using roadway designer from Geopak and not InRoads.)
Geopak Version: 8.11.07.227
