CR - MX V8i ss1 - Default feature and styleset
When I run inputfiles and draw models from my inputfile or through the MX Explorer. The popup appears for selecting the correct Feature and Styleset if it isn't defined in the defmod.txt. That is ok if the modelname doesn't match with the model masking. But my modelnames are most of the time accoriding the modelname masking.
If I copy strings interactivly from one model to another, it works correct and the correct feature and styleset is being added.
With regards,
Gunther Groenestein
MX: 08.11.07.246
Windows: 7 x64
