When reviewing Vertical Alignments, Stopping and Headlight Sight Distances are not always shown in the report. It appears that they only show when the entrance and exit grades are in the opposite direction (G1="+" and G2="-", or vice versa). If the two grades are in the same direction (G1 and G2 are both "+" or both "-"), the sight distances do not show in the report. Is there an option that I am missing?The values are calculated in InRoads and can be displayed using Vertical Annotation, but it would be very helpful if these were also included in the Review Vertical Alignment Report.
Thanks in advance.
Hi Dave,
I did some research and talked with Richard. We should be reporting the sight distances but we missed it. I've added this omission to be fixed in a future update.
Nice hearing from you.
Mike
Mike,
Thanks for the reply and logging this to be added to a future update.
It has been a while since I've been to any Bentley event, so it's good to know that much of the same group is still around. Hope all is well.
David
