How to get Sta-Offset report to include superelevation events
Superelevation for the alignment was created in Inroads Suite V8i SS1 roadway designer.   When I pull cross-sections the Superelevation stations are included.  When I run the Station-Offset report the superelevation stations are not included.
Any ideas? TIA
  • There is another way that might be of use. Add the ROW alignments to a surface as features draped on the existing ground.
    Create cross sections with the ROW features included as crossing features. Set the Controls > Critical Sections turning on Horizontal Cardinal Points and Superelevation Event Stations.
    Open Cross Section Report and choose the Set, Surface with the ROW features, toggle on Selected Features and ID the ROW features in the list. On the Slope Staking tab, toggle on Generate Slope Stake Points and choose the radial control for From Surface and choose the ROW features, left and right.
    Apply the report and when you are at the Report Browser, select Evaluation > Cross Sections ToCSV.xsl. The report can be saved as a text file and opened in an Excel spreadsheet.
    Mike
    This is a test
  • The ROW features do not show up in the cross-sections.  I can display the ROW features in plan, and when I review features they show up.  Inside the cross-section they are not there.  Also tried to add after creation but the ROW features did not show up as an option.  The features created by roadway designer did show up.
    I added the ROW features to the surface by importing alignments, as breaklines w/ do not trianglate, and setting elevation to surface.
    What am I doing wrong?
    T7_D4-Try2_Features.dtm
  • Do you have the ROW Style set to show points in the cross section?
    If this doesn't resolve your problem then call Bentley Support and they can assist the last bit.
    Mike
    This is a test
  • Yes it is.
    I'm going to start from scratch and see if I can pick up my error - if that doesn't work I'll give support a call.
Reply Children
