Any chance of adding Cross Section Navigator to future versions of Geopak Survey? We find that the surveyors would use this tool often if it was included in Survey.
I'd like to throw my support behind this, but for InRoads Survey. The surveyors are often asked to survey cross sections and need to create and review their efforts. But currently need another package to complete the task.
Marym,
The enclosed .zip file contains a .mvba might be of use to you for navigating through cross sections that were created using Geopak. It scans the active file for cross section cells named XSCELL. This application was originally developed for PowerDraft users so that they had the ability to navigate through Geopak created cross section files easier. Also incuded in the .zip file is a pdf help file that explains the applications use.
