Cross-section sheet layout - problem with elevations
Hi, I'm having a problem with the sheet layout--the sheets are not being laid out at the such that the proper elevation label is lining up with the cross section correctly.  i.e. the cross section is too low or too high in the sheet with respect to the labels.  Does anyone have any ideas?
Parents Reply Children
