Has anyone ever received a triangulation error with point coordinates that are far beyond the model limits? In my case the point where Inroads identifies untriangulatable data is 1200 feet away from my model.
I thought it might be an incompatibility thing because I'm running XM on Win7x64 but I tried with V8iSS2 and on an XP machine with XM and got the same results. I've tried using a new dgn file and tried creating a new .ird file and copying the corridors over.
-Tim
Hello Tim,
I suspect it is one of the triangulation range points. Please contact Bentley Support and they can assist you because the data will be needed to provide an answer.
Mike
Thanks Mike! Kevin at tech support said that northing/easting/elevation it spits out is completely useless in debugging the problem. He had me toggle "Extended Data Checks" under triangulate surface and that processed fine.
