i have an existing surface (dtm) and i am putting in a proposed concrete pad at a certain elevation. i want the pad to tie into the existing ground at 2 to 1 how do i generate a new proposed surface showing the 2 to 1 slope .
There's a workflow example on the Wiki page:
communities.bentley.com/.../site-modeler-basic-design-workflow-tn.aspx
There's a Dataset link too, so it looks like there's some example files available for download to practice with.
Would you please share some experience on why you recommend not using site modeler?
I especially like the function of "Raise/Lower surface by Volume", It can automatically raise or lower the surface to get a balanced volume. If you don't use site modeler, how can you achieve this result?
