Corridor/Roadway designer/Cross section help
Hello, can anyone help? I Use BRT, but this is more geared towards the actual roadway.  I copied and pasted what I had sent out in the other forum.
I created a corridor, I then used the roadway designer and processed. In the roadway designer, it shows the existing surface and my corridor in a section view. It looks cool and it shows my end components at work. After I process, I went to cut sections. I have to click on my corridor surface I created and my existing surface for them to both show on my cross sections. At this point something it is not coming out like I need it to. The template is coming out as a surface, it needs to show the actual template with all components in it, like the tie, ballast, and sub-ballast. I also need it to be the color I selected it. I am trying to get my cross sections to have the existing surface, with the template/proposed surface on top showing the end constraints. Just how it looks in the roadway designer. Anyone have an idea?
