Cross Section: proposed surface/end condition doesn't intercept existing ground
I am using Inroads Suite XM Edition.  When I create my cross sections I notice that my proposed surface, in many cases, does not actually meet the existing ground surface like it should.  In roadway modeler, the section views all look correct, but in the actual cross sections the end conditions sometimes end short of meeting the existing ground surface and sometimes they go beyond the existing ground surface.  This applies in both fill and cut sections, with and without "rounding" option for the cut component.  Again, when viewing the sections in roadway modeler, everything looks correct.  The "End Condition Properties" in my template has the "End Condition is Infinite" option checked on as well.  Can someone tell me how to fix this issue?
  • I understand all of the comments and explanations.  What has been said does make sense.  I will drop my templates at shorter intervals to see if this makes a difference.  In the past I have been reluctant to drop templates to frequently due to the time it takes to crank through everything, but in this case it may make sense to do this.  Thank you everyone for your support, it is greatly appreciated.
