MX tip files
Anyone experienced with MX tip files and using them to produce drainage profiles. I have it neally looking how I want, but not quite there. I want to show the pipe grade above the datum and I can do this, however when doing this it centre aligns with the actual pipe instead of centre aligning with the box that is drawn in the annotation. So when short length pipes are present this becomes an issue. Also the chainages do not align correctly except when at the start and end of a line/trunk. I also want to display a heading below the chainage box labelled 'Pipe Length' which aligns with the pipe lengths when they are placed. I have attached a picture of what my profile looks like for convenience, any help is appreciated.
Jason
