All-
I just got word from one of our largest clients that the attached LandXML surface file cannot be imported into his Civil3d.
Can somebody test it out for me and let me know what is going on?
I have also attached the GeoPak Tin that it was created from.
PowerCivil 08.11.07.426
thanks
t.
The GeoPak Tin
Tom: I tested here using our newest DTM engine. Works fine. Looks reasonable.
Robert GarrettSenior Product EngineerBentley Systems Inc.
Robert-
Thanks for taking a look at it. Do you have a Civil3D install to test it out on? Or can you pass it to somebody at Bentley who does? I really need to figure this out. This is a state job and they are letting us use MicroStation/GeoPak because it has worked seamlessly on past projects.
Thanks for any help you can give.
Thomas,
Your XML file imports fine into my C3D 2010. I'd say the problem is on your client's end.
Neil Wilson (aka Neilw)
Power Civil v8i 08.11.07.245
AutoCAD Civil 3D 2018
That is good to hear!
kind of.... Would you mind calling and telling him? :0)
