I am using MicroStation V8i (SS2) InRoads (SS2) and need to adjust some cogo points elevations by a specific distance. For example, if I have a group of points with different elevations that I would like to raise or lower by 3" is there an easy way to do this? I tried using Geometry---> Cogo Points---> Edit Multiple---> Reassign Elevation but, it seems that you can only assign a specific elevation, not a distance to change by. At this time the way I am changing points is by exporting to excel, editing, and re-importing. There should be a way to do this inside InRoads I would think... Any help would be appriciated.
Thanks in advance,
Nate
I do not think there is a way to do that with InRoads only. Your workaround to export cogo points via XML report and use Excell or other software to adjust elevations and then import cogo point with Text Import Wizard is the only way I know. It works fine and is quite fast.
Adam Wieczorek
Geometry>Utilities>Transform might do it for you. Make a copy of your geometry project before you try it.
Thank you Paul! That was exactly what I was looking for.
My first idea was to look there but I were looking for delta elevation method. I can recall that there was such a method in Inroads 2004.
Thanks Paul, it really saves time.
