I received a survey from geodesist saved to file with DTM extension [ map.dtm ]. Does anyone know how to import it to MX?
Best regardsAleksander Zamorski
Could You tell me if there is a solution with pre XM edition (without PowerDraft environment and without Data Acquisition)?
Best RegardsAleksander Zamorski
If you want to import the DTM directly? No, not that I'm aware of.
I don't remember by heart when the LandXML import function was added to MXROAD, but I'm rather sure it was pre XM Edition.
I would recommend to ask the survey company to give you a LandXML file instead of the DTM file. For pre XM Edition it probably must be LandXML 1.0.
Alternatively, InRoads also has a GENIO translator (> InRoads Application Add-Ins). Perhaps the survey company could even provide a GENIO for you.
Best Regards
Wolfgang
