How do you import/export 1) Latitude/Longitude from a GPS file and 2) shape files along with the associated .sbx .dbf .prj .shx files? Thank you, -Nat.Adam@AtkinsGlobal.com
You might be better off using Bentley Map. Since you're using InRoads V8i SELECTSeries 1, you already have it available.
I'm sorry, i don't see Bentley Map anywhere in Microstation. Is it an add-on? part of InRoads?
Bentley Map is delivered with InRoads Suite.
Bentley Map is included in the SS2 InRoads install, not sure it may not have been in the SS1 package. But if you start InRoads then look at the MicroStation Menu > Applications > Map should appear and be available to activate.
In SS1 Map may have only been avaliabe from the InRoads Suite but in SS2 Map is avaliable from InRoads.
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
