IR V8i SS2+
How do you get the extended geometry descriptions to work with the Survey > Survey Data to Geometry command? I have a fieldbook that contains notes, so I've set that up in the extended descriptions portion of the dialog. I tried all three types of description options for the features (style descriptions, attribute and code) but I'm still not able to get the survey notes into the geometry file when i use the Geometry > Cogo Points > Edt/Review Extended Descriptions command. I attached the test fieldbook.
Any ideas? Thanks in advance!
seversk, here is a tip I wrote on this topic. envisioncad.com/.../geometry-extended-descriptions
If it still doesnt work let me know and I will test your FWD file.
Bob Mecham
Hi Bob - it still didn't work, but then I tested it with the default Bentley XIN file and it works. So it looks like there's a setting that I need to change in our agency XIN. Thanks for your help!
