Is there a way to change to a different horizontal alignment by selecting it graphically without have to go to the InRoads Explorer window everytime. If not, what command can I associate with a function key to toggle the Project Settings dialog box?
There is such a way. Just click Active Geometry (Geometry Menu) icon with Ctrl. Then you can locate and select active HA graphically. You can customize your toolbars a little bit to have this icon somewhere on top.
Adam.
