I am trying to transpose my geometry after I have already modeled my corridor in roadway designer.
Geometry -> Utilities -> Transpose GeometryGeometry -> Horizontal -> Stationing
This was successful-- the next step was not.
Opened up Roadway Designer, corridor not processed, templates not displayed. The surface/vertical profile appears to be correct but I do not see anything in the upper right window of Roadway Designer (usually plan view) or the right window (usually cross section).
My template drops, point controls and parametric constraints appear to have changed stations (not sure if correct or not as I cannot see anything graphically)... but nothing is showing up when I push thorugh the corridor.
Any suggestions on getting Roadway Designer to accept the Geometry Transpose without having to re-create the corridor?
Heather
You could start by checking your Manage Corridor dialog the Station Limits are possibly backward.
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
You might also want to check your vertical alignment to see how transposing your horizontal affected it.
