I'm using Geopak Corridor Modeler to create DTMs and corridors. I was wondering if there is a way to visualize the DTM components into a file outside of the "Create Surface" dialogue when creating a surface?Can this can be done from the DTM that Corridor Modeler outputs?
Not in GEOPAK. The only way to visualize in GEOPAK is while you are creating the surface. I believe this can be done though in InRoads.
Derricke
