Convert Tin Surface File to InRoads DTM Surface File
(Sorry if this question has been posted before)
I have a Tin file created with Geopak.  I need to convert it into a DTM surface in order to use InRoads.
Is there a way to use the triangles to extract them into a dtm surface , and if so, how can this be done?
I currently use InRoads V8.8 , but I do have access to InRoads v8i - in case there is a direct translation.
Thanks for any help.
p.s.: I am dealing with a huge Tin file as it is for a big interchange. Creating my own dtm file from existing contours is not an easy task, and too much time consuming.
Parents Reply Children
