hi,
I want to generated grid and show the volumes in the grid, right now we get as a text file!
is there a method to create a dgn, with grid and volume of each grid!
awaiting reply.
regards,
vivek
Combine the grid volume command with the Create Isopach command, using grids and the view gridded surface command
thanks for your reply, but in isopach annotates the difference in elevation between two surfaces, but i need to show volume. can you bit explain? thanks for u support.
You are right. I recalled someone using those values to calculate volumes by then multiplying them by the area of the grid. So, possibly a macro to read those numbers, calculate the volume and replace the height with the volume could work.
thanks mate
