I can not get the Civil Geometry stationing to display. I have turned on the Auto Annotation to True and Auto Presist to True. I have set the Drawing scale and tried it at different scale. Is there something I am missing?
Robert GarrettSenior Product EngineerBentley Systems Inc.
May I email you my ddb file? I believe I have it setup correctly with all the scales. I would like if you would check it for me.
robert.garrett@bentley.com
Hi David:
Took a look at your DDB and it seems alright. Looking at item "Main - Alignment with Stationing". I see tic marks and station labels defined for a variety of scales. this is good. The defined scales include 10, 20, 25, 30, and a bunch of others.
To get the civil geometry annotation to occur automatically, go to Microstation menu > Settings > drawing Scale. Set the scale here to 1"=10' or 1"-20' (or more likely 1"=50'). In other words one that matches something in your DDB item.
Thanks for looking at it. I have been trying different "Drawing Scale" and it still does not display. Were you able to get it to work?
