are there any materials or guides available for xsl stylesheets editing and creating?
I would like to create my own reports but I can't find any guides or reference books. Especially, I need to know what values can be annotatated (and by what commands) for geometry points (radius, level, etc) and for elements (length, type, etc.).
Cheers
What I have found, is that many books on XML have some portion of the book devoted to XSLT or XSL. It is really a hit or miss proposition that you will find useful information. I would not buy a book without being able to look through it and look at the amount of information devoted to XSL. Unfortunately, much of these books are about creating XML and we don't really need that information.
I rely heavily on Google Search and also look at many of the example reports delivered with the product.
I will look at the books I have and post a list of those that have been useful for me. Books will be added as I have time:
I forgot to mention - as XML is less popular subject matter, you may find books at clearance prices. My $29.99 XML Pocket Consultant cost me a whopping $5.99, as did the TY XML in 21 Days. Makes buying a book for 20% of its content much easier to swallow.
Feel free to post more questions with specifics and you might get lucky. ; )
There are two PDF files explaining some possibilities in the XML Data folder and I also believe there is some information in the Release Notes (or some other technical docs) Wiki pages - possibly even a video.
Start by modifying a copy of an existing report to add or remove a column.
And get Notepad++ and in its Add-in Manager, configure it to get the XML Tools. Get the newest version.
Good Luck!
CaddCop, thanks for your response - it's very helpful. You are absolutely right - it's good to start by modifying an existing report and this my way of working at the moment. :)
I was looking recently for a xsl name for rail Equilibrium Constant and it appeared this constant is not coded in xsl... it needs to be calculated... The most important constant for all kinematic values is not achievable directly. Funny... :)
Anyway, I will look for some bargains on books you have listed and probably will contact you if I have a difficult question. ;)
Cheers.
https://itunes.apple.com/us/app/rail-library/id784641429?ls=1&mt=8
Some of the best books on XML and related technologies such as XSL (a.k.a. XSLT) are published by O'Reilly.
Here are some …
The first in the list, author Doug Tidwell, contains reference sections.
Of course, there's plenty of help and tools on the web.
Cheers!
Of course, xml/xsl is not the primary problem. The problem is to get anything written for xsl in InRoads, eg. a list of all commands and parameters (@length, @radius, etc...).
Have you read this two documents in the InRoads...\XML Data\en Path:
Creating XML Lookup Table Style Sheets.pdf
Creating ASCII Output Style Sheets.pdf
I can find them with my IR 8.11 Installation.
Frank
