I have an ASCII drainage network file but is not successful in importing it in inroads.
Could somebody tell me what is wrong with my data and format?
BEGIN_FORMAT PIPE_FORMAT {Pipe_id ent_id ent_ie ext_id ext_ie dia shape type} MANHOLE_FORMAT {Man_id top_elev} NODE_FORMAT {node_id y x} END_FORMAT
PIPES PIPE1 MH1 13.636 MH2 13.536 750 1 0 PIPE2 MH2 13.536 MH3 13.436 750 1 0 MANHOLES MH1 16.0 MH2 15.0 MH3 14.0 NODES MH1 5515.050 1687.000 MH2 5515.050 1732.000 MH3 5515.050 2032.000
Thank you very much.
By the way, i'm using Inroads v8i.
-chris
Chris, I copied your text to a .txt file and then imported to an empty .sdb with no issues (using InRoads Ss2 08.11.07.536). I got 3 manholes from left to right connected by the 2 pipes. When in the workflow are you getting the error?
