InRoads Surface Features/Annotation Scale
Hello fellow InRoads Users,
Im about to begin the process of updating some InRoads cells that we have been using for some time and I would like to take advantage of MicroStation functionality in MS-SS2, specifically Annotation cells.
The limited testing that I have done seems to work with text assigned a text style within a cell, but I haven't had much luck with just assigning a cell to be an annotation cell.
My workflow is to place features such as EOP, ROW, Building face labels and etc... at an InRoads scale factor of 1 (one) and let MicroStation annotation scale handle the scaling.  I have a cell set as an annotation cell for testing.  It places correctly outside of InRoads,but not when placed by InRoads.
Have any of you had any luck with this?
Thanks in advance for your input.
Chuck
  • Chuck, my current workflow is to display the cells out of InRoads at a scale of one.  Then select all cells and apply the MicroStation keyin "annotationscale add"  Then the cells will work with annotation scale.
    That's a great tip,  Bob!
    Frank
    since 1985: GIS, CAD, Engineering (Civil)  Senior Consultant : [Autodesk Civil 3D , Esri ArcGIS, VertiGIS: in previous days : Bentley MS V4 - V8i, GeoGraphics, Bentley Map V8i, InRoads,  HHK Geograf, IBr DAVID] :  Dev: [C, C++, .NET, Java, SQL, FORTRAN, UML]
    [direct quote by: http://en.wikipedia.org/wiki/Helmut_Schmidt]: "Wer Kritik übel nimmt, hat etwas zu verbergen"
    Wer Grammatik- und/oder Rechtschreibfehler findet, der darf sie behalten :-)
  • Thanks for your responses....
    Our current workflow is still workable & efficient.  I hate to change things up for just the limited number cells that I was hoping to change.  I'll just stay the course and make the change when the functionality becomes available..
    Thanks to all again for your responses
