Hi all,
Been playing with inRoads alot lately.
It says in the manual that most functions return only THREE different values, success = 0, errors = Whatever, or no valid license = -1. I cannot find anywhere to translate the errors, so I have to guess what they mean:
F.ex.
Loading a DTM that is allready loaded returns "error" = 1211. I GUESS!
Is there somewhere I can look up those codes instead of having to guess?
Regards,/Torben
(Brrrrr. The climate here is horrible..)
Did you try to call scadSDK_getErrorMessage on the error number? From the help file this function is used to interpret the error ids.
Here is the VBA declaration for it:
SCadUtility.txt:Public Declare Function scadSDK_getErrorMessage Lib "SCadSDKAT"
(ByVal errMsg As Long, ByVal errNo As Long) As Long
HTH,
mark anderson [Bentley]
Visit me at https://communities.bentley.com/communities/other_communities/bentley_innovation/default.aspx
Hi Mark, I did try that, but so far I have failed to use it. There was also something about it not working when running from outside process. But VBA would be "inside" wouldnt it?
I will try again, thanks!
*...coding...*Here is what I got so far, (and it doesnt fail now :):
Error code 174: Returns Øì(ûÈwí(®All other codes from 1 to 250.000 returns nothing.....
Judging by the scrambled returned code something is going wrong.But judging by the fact that something is returned, I am on the right track :)
My Code:
Function inRoadsGetErrorMessageAsString(ERROR_CODE As Long) As String ' Try to get some info.. Dim byts As longString ' 174:Ìì(ûÈwí(® If Not INROADS_RUNNING And Not INROADS_SYSTEM_TESTED Then inRoadsInitialize INROADS_STATUS = SCadDTM.scadSDK_getErrorMessage(byts, ERROR_CODE) If INROADS_STATUS <> SDK_SUCCESS Then inRoadsGetErrorMessageAsString = "UnableToTranslateErrorCode:" & ERROR_CODE Else ' translate byts to a string inRoadsGetErrorMessageAsString = byteArrayToString(byts.s) End IfEnd Function
And the modified declaration:
Type longString s(256) As ByteEnd Type' Error message TEST:Public Declare Function scadSDK_getErrorMessage Lib "SCadSDKAT" (ByRef errMsg As longString, ByVal errNo As Long) As Long
And the loop.. that only returns something for 174
Sub testerror() Dim i As Long, s As String For i = 0 To 250000 s = inRoadsGetErrorMessageAsString(i) If s <> "" Then Debug.Print i & ":" & s Next i Debug.Print "Done!" End Sub
System: Win7 64bit 16GB Ram - microStation V8i SS3 08.11.09.578. + PoinTools CONNECT. - Intel i7-4800MQ CPU@2.70GHz, 4 core / 8 Logic proc.
Shameless self bumping..
I have still not managed to get the error lookup working.
(The bump resulted in the Post being moved to the RoadDesign forum, from the uStation VBA forum)
