Draw more profile for an alignment
I have an alignment with horizontal and vertical. But now I want to add a profile. I've tried coping the alignment to another model and vertical design normaly. But I can't show detail annotation for both profiles. How do I create profile drawing with annotation for both vertical 1 and 2.
  • I am assuming you are using 'Final Drawings' to create the profile drawing, and not an input file.
    I have two alignments, identical in plan, with a different profile - as you did, I just copied ant first alignment, and then amended the vertical profile.
    I used Final Drawings to draw the profile of the first profile, with the annotation required.
    I then drew the profile of the second alignment in another position in the desing file. (I used the CAD functions to deleted anything I did not want). The resut was as shown below. The left drawing is the original, the right hand one is the second profile.
    As I am trying to create a plot file with the two profiles, I created a new CAD model (a SHEET model), and using standard CAD reference functionality, I created the following to plot.
    In total, that took (maybe) five minutes - from creating the second progile to the plot-ready sheet. (If I had the time to set up a final drawing style, I could have place the secong profile exactly on the top of the first and saved myself the time on the reference file move). If you are going to do this regularly, make a second style for profile 2 :-)
    HTH
