USING AUTOCAD 2011 AND INROADS FOR PLAN AND PROFILE PRODUCTIONS
HELLO GUYS AM NEW IN THIS COMMUNITY, PLS AM HAVING A VERY HARD TIME USING AUTOCAD 2011 AND INROADS FOR PLAN PRODUCTION, PLS ANY IDEAS AND SUGGESTIONS WILL BE HIGHLY APPRECAITED. AM AN AUTOCAD USER AND AM RUNNING INROADS SELECT SERIES 2, PLS ANY SPECIFIC WAY OF CREATING THE PLANS AND PROFILE USING INROADS WITH AUTOCAD AS THE CAD PLATFORM. THANKS GUYS..
  • PLS use Microstation ;-)
    Frank
    since 1985: GIS, CAD, Engineering (Civil)  Senior Consultant : [Autodesk Civil 3D , Esri ArcGIS, VertiGIS: in previous days : Bentley MS V4 - V8i, GeoGraphics, Bentley Map V8i, InRoads,  HHK Geograf, IBr DAVID] :  Dev: [C, C++, .NET, Java, SQL, FORTRAN, UML]
    [direct quote by: http://en.wikipedia.org/wiki/Helmut_Schmidt]: "Wer Kritik übel nimmt, hat etwas zu verbergen"
    Wer Grammatik- und/oder Rechtschreibfehler findet, der darf sie behalten :-)
  • What kind of problems are you having?
    I have used it in earlier versions and was able to do almost everything in AutoCAD with InRoads that I could in MicroStation. I had access to both and was more comfortable in MicroStation but often had no choice but to work in AutoCAD.
    Our current workflow is only for Survey, so my recent experiences are not using any profile tools.
    (By the way - all capital letters is considered shouting, according to the rules of the net.)
    Charles (Chuck) Rheault
    CADD Manager
    • MicroStation user since IGDS, InRoads user since TDP.
    • AutoCAD, Land Desktop and Civil 3D, off and on since 1996
  • Caddcop, i completely forgot that i was using all caps, anyway it is noted.  Actually am new to inroads and am seriously working hard to really learn how to use it.   Basically these are the problems am facing anytime i tried to create the plan views in autocad.
    1. First, when i click on the apply button while in model space in autocad, the process will begin and suddenly my autocad will not respond anymore, and i have to terminate and restart inroads and autocad.
    2. Secondly, i decided to try it in paper space, now when i click on the apply button it process and creates the views, but  it creates the views such that they appear scattered around and very tiny, i mean they just don't look right, my match lines are not in their proper location also the north arrow is also not in d right place, also my border is rotated and scattered around.
    Pls Caddcop, can you please share your workflow with me when you are using the plan and profile generator cmd  specifically using inroads and autocad. I don't mind if u can give me an indepth explanation. Thanks
    AKANDE PAUL
    CDSS NIGERIA (ASST PRODUCT MANAGER AND TRAINER)
    BENTLEY PARTNER IN NIGERIA
  • pls guys i need assistance in using autocad 2011 with inroads for plans and production, i need a basic workflow, from scalling to the sheet generation as well as the plan and profile views generation. Thanks guys
    AKANDE PAUL
    AKANDE PAUL
Reply
    AKANDE PAUL
  • I suggest you post the version of AutoCAD, OS and ram.
    You might also check with support. They should be the first line of defense. I will post here for suggestions and occasionally to seek help with a problem, but logging a TR is a good idea whenever you cannot get the software to run without locking up.
    I have not used plan and profile generator with AutoCAD but have cut cross sections. However it was many version ago - AutoCAD 2000 and who knows what version of InRoads.
    CADD Manager
