I need to annotate my cross-sections showing the computed areas and volumes of my pavement layers and subgrade on each section. I have made my subgrade type to subgrade and the rest of my pavement courses to substratum. I am able to produce a xml report withe style "EndAreaVolume.xsl" sheet. The information is good and would like to annotate my sections with this information.
Any help would be appreciated.
Joe
Make sure the Tabulated Area options are toggled ON and that should add the annotation to the location specifed, Top Left for Area and Top Right for Volumes if set as shown below.
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
Mike, Thanks again for the help!.
The Tabulated Areas and Volumes are base upon the "Style" associated with the component. If you have multiple components with the same style the calculations are totaled in the quantified annotation of the section. Be careful about naming your styles. Mulitple styles for mulitple components should be used.
