Hi Guys,
I am working in Mxroad 2004. I was in need of vertical ground profile atan offset left and right from the center line (MC__). This method has an advantage to get information on the drainage property. One thing that i learned from experience is have an offset master string from the main master string and produce the ground elevation/profile separately for each of the offset masterstrings.
But similar to the extraction of carriageway and shoulder in a vertical profile, is there any other method.
Hi Aman,
Offset the master string using 100 commad whcih creates edge strings (say MC00 to CM00). Use draping command to apply the ground level to CM00 using 177 command. Display the string CM00 in profile
Devaraju
